3d mapping - single object - 2 projectors
  • neuralF
    by neuralF » Thu Jul 14, 2022 1:23 pm
    Hello. Is it possible to do projector stacking for 3d mapping in madmapper? One is not bright enough. Are there any tutorials?
  • neuralF
    Re: 3d mapping - single object - 2 projectors
    by neuralF » Fri Jul 15, 2022 1:21 pm
    Should I just calibrate the model on first projector and then on the second one separately? Will it work?
  • rna_parts
    by rna_parts » Mon Jul 18, 2022 6:20 am
    Thats what I did.. Have a 3d model so from a different angle you have to skew the output to fit the different angle. so for each projector, (in my case 2) I use a duplicated output.
  • neuralF
    by neuralF » Mon Jul 18, 2022 10:56 am
    thank you bro
