New to MM and want to use multiple scenes - HELP!
  • Indy07
    by Indy07 » Sun Aug 28, 2022 1:19 pm
    I’m trying to create a projection show for my masters degree show and am very new to MM so would appreciate any help.
    I have multiple movies that I would like to run simultaneously for the same amount of time but showing on separate surfaces which I have created using masks.
    One of the movies has the audio track attached.
    I also have a title page and end credits that are each on their own movie.
    How can I:
    1) Use scenes or cues to make the movies play at the same time (total movie length is 137 sec so I don’t want it to extend beyond this by all the movie run times adding up if that makes sense) I have 5 movies, each at 137 sec but I want total run time to be 137 sec, not 685 sec
    2) Make sure the title and end credits play at the start and end of the project
    Thank you :D
    Re: New to MM and want to use multiple scenes - HELP!
    by mad-matt » Wed Aug 31, 2022 9:05 pm
    You can force the scene to restart all movies. Then starting the scene will restart all movies and they will play in sync. To do so, just select your scene, open the cue inspector (right button in the cue bank toolbar), select in the treeview /Medias/MyMovie.mov/Restart and check the Value checkbox. Do it for all movies.
