OSC bug?
  • Teunkneus
    OSC bug?
    by Teunkneus » Fri Sep 02, 2022 12:19 pm
    I have created a 3 wall projection.
    With OSC I want to change the projections which works quite ok, but..
    Sometimes it doesn't place a video on a single wall but it throws them on all three, which is certainly not meant to.
    So it works 9 times out of 10, but since it has to work automated it's quite frustrating.
    What I did is select with an osc command the quads I need to change the video and then with osc command select the media.
    But sometimes it reacts like it somehow selects all the quads. When I check it doesn't seem in the UI that it actually selects them but it does throw the video on all of them...
    Is this a known issue?
  • Teunkneus
    Re: OSC bug?
    by Teunkneus » Fri Sep 02, 2022 4:03 pm
    It seems adding a 6th output to the pc solves the problem... will update if still not fixed.
    Not that this sounds logical
    Re: OSC bug?
    by mad-matt » Mon Sep 05, 2022 4:05 pm
    > an osc command the quads I need to change the video and then with osc command select the media but sometimes it reacts like it somehow selects all the quads
    There's no such known issue. Can you reproduce it ? Which version of MadMapper ?
    You could also use the control "/surfaces/Quad-1/visual/number"
    Or, depending on your project, use cues with different media assignment to all surfaces.
