MadMapper 5.1.6 Released
    by MADben » Fri Sep 16, 2022 4:55 pm
    Dear mappers,
    A new version has been released with may fixes improving stability and listed below in the release notes.
    (It's free for v5 owners, grab it in the Downloads section of your user account, MadMapper website)
    MM 5.1.6 Release Notes
    ADDITIONS
    + Added back support for Canon EDSDK in Apple Silicon (M1) build
    IMPROVEMENTS
    * Rotating lines / masks elements of surfaces supports SHIFT+rotate to jump by 22.5 degrees
    FIXES
    - Fixed Fixture parameters display issue when a fixture definition name is too long
    - Changing media selection could restart a movie in "play once" mode when it finished
    - Spatial Scanner was listing video loopbacks as camera sources
    - Fixed publishing resources in the online library depending on system locale
    - Fixed laser visualization “device number” when a video projector comes first in the list
    - Fixed cue bank auto play in “left to right once” mode
    - Fixed rotation issue in bezier element items (lines or masks)
    - Fixed trigger controls (ie "start cue" / "media restart"...) being executed on project load with DMX channels even if value is zero
    - Fixed a possible issue publishing Materials or FX to online library depending on computer locale region
    - Fixed sACN universe number when importing DMX Fixtures from CSV & accept "," and ";" as separator
    - Fixed issue in space scanner when MadLaser is not available
    - Fixed scrolling in list when duplicating a module
    - MadLaser: fixed possible issue driving multiple AVB outputs
    - Fixed Enttec Pro Mk2 second output with D2XX
    - Fixed engine smoothness when adjusting audio input level on Windows
    - Fixed Controls with toggle enabled when on/off is received within one frame time
    - Fixed an issue in Laser Dispatching introduced in version 5.1.3
    - Fixed DualShock3 (PS3 controller) with macOS Monterey (still not working on Windows)
    - Fixed Moncha Laser DAC on Apple M1
    Enjoy!
    The MAD Team.
  • tontechnik
    Re: MadMapper 5.1.6 Released
    by tontechnik » Thu Oct 20, 2022 3:18 pm
    v5.1.6 crashes with AMD Radeon Pro 22Q3!!! I had to reinstall AMD Software/Driver to 22Q2, because MM has massive issues with resolutions on all outputs of our Radeon Pro W5700.
    by mad-matt » Fri Oct 21, 2022 10:27 am
    Maybe there's an issue with Direct3D - OpenGL interaction in this driver version. We'll test it. DId you send any crash report ?
    You say MadMapper 5.1.6 crashes, do you mean previous releases don't ? I suppose it happens since MadMapper 4.0 (where we added support for Direct3D output to get a perfect synchronization with screen frequency)
    Thanks for reporting.
  • tontechnik
    by tontechnik » Sat Oct 22, 2022 2:48 pm
    I don't know. But the 22Q3 is newer than MM 5.1.6
    Perhaps AMD did any changes in their new driver version...
    Thanks for testing it!
