Mapper not outputting to Projector
  • clon john
    by clon john » Thu Sep 22, 2022 7:18 pm
    hello , I have setup a projector for mapping a wall to test. I can see my laptop mirrored and extended to the projector fine. when I select image and push it to output I can see it monitoring fine on output monitor. With projector selected I use dropdown menu and change from none to BMD Hdmi which is the Hdmi to SDI converter ( already working via mirrored or extended with desktop pic)
    Any help greatly appreciated.
    thanks John
    Re: Mapper not outputting to Projector
    by franz » Mon Sep 26, 2022 10:41 am
    you have to go fullscreen
    Menu Output / Fullscreen
  • casino_man_dan
    by casino_man_dan » Fri Oct 28, 2022 5:01 pm
    I've also found that I have to exit maximised screen on the laptop itself otherwise it refuses to output to the projector FYI
    by Pierre Guilluy » Mon Oct 31, 2022 11:39 am
    Thanks for the feedback, next update will prevent this problem from happening.
