Reusing media in the same scene
  • martenbiehl
    by martenbiehl » Fri Oct 14, 2022 2:26 pm
    Hi everyone,
    I am stuck getting two projectors play the same file independently from each other:
    I have two projectors both playing the same set of files. I set up cues for each projector that are then triggered by OSC. This all works, except if both projectors play the same file. In that case the second projector jumps to the position in the file that the first projector is on.
    If I set the restart property both videos are restarting as it is a property on the media.
    How can I get both projectors to play files independently?
    Best
    Marten
    Re: Reusing media in the same scene
    by franz » Mon Oct 17, 2022 10:24 am
    duplicate the movie file in your media bin. You'll have 2 instances of the same media, each playing independantly (thus decompressing 2 times)
  • martenbiehl
    by martenbiehl » Tue Oct 18, 2022 7:04 pm
    Hi franz,
    thanks a lot that does work quite well. I was fearing that I needed to create files for each projector but that makes it a bit easier.
    Best
    Marten
