Ability to fast-switch to specific cue bank
  • jasonbeyers
    by jasonbeyers » Mon Oct 24, 2022 11:25 pm
    When using a Madmapper project with multiple cue banks in a live setting, it is a little cumbersome to switch cue banks quickly. Let’s say bank 1 contains cues for projectors (videos, materials, etc) while another bank contains lighting cues. Only one bank can be visible at a time, and it takes two clicks with a mouse to change cue banks at the moment.
    If Madmapper’s control system had a “select cue bank by name” trigger, users could rapidly flip through their cue banks in a live setting. I’d imagine “keyboard”, “MIDI”, and “OSC” being the most useful input types for this. And I would get a ton of use out of this!
    Re: Ability to fast-switch to specific cue bank
    by franz » Wed Nov 02, 2022 3:29 pm
    +1
  • jasonbeyers
    by jasonbeyers » Wed Apr 05, 2023 8:03 am
    I see this has been added now - thanks so much! It's working well, and I can now make the UI jump to a specific cue bank via OSC commands. I'm actually using an OSC-out module to do this (routing back to MM), so that I can map this to a MIDI control.
    I really appreciate your team adding this!
