Those who make the forum leave us alone with the application. no supportWhen is an update due to be released?
Thnx u benoitModul8 3.1.12 is now available on Yourspace and fixes the menu bar issue on macOS Ventura
Feel free to let us know if you face any other issue
Problems with mac os ventura. The program works fine in its raw form. But when I install some plugins there is a problem. eg when black flash, lte clip control etc are loaded, the top bar does not work.
Could you describe what plugins (modules?) you are using and what manipulation lead to the top-bar not being usable?Problems with mac os ventura. The program works fine in its raw form. But when I install some plugins there is a problem. eg when black flash, lte clip control etc are loaded, the top bar does not work.
Lte clip controlCould you describe what plugins (modules?) you are using and what manipulation lead to the top-bar not being usable?Problems with mac os ventura. The program works fine in its raw form. But when I install some plugins there is a problem. eg when black flash, lte clip control etc are loaded, the top bar does not work.
Could you be more specific?Lte clip control
Black flash
Users browsing this forum: Baidu [Spider] and 12 guests
