problems playing back audio
  • casino_man_dan
    by casino_man_dan » Fri Oct 28, 2022 5:11 pm
    Each time I open up my current madmapper project (both v 5.1.5 and 5.1.6) several audio clips from the audio modules won't play back. I can see them there and the filepaths...all in exactly the right place and I haven't moved the file storage locations but they won't play. I have to drag in the same clips again into a new module and then it plays fine....but I have so many cues and it's different ones missing everytime I open so I'm tearing my hair out a bit!
    Any workarounds??
    Also, I can't switch between headphone output and built in speakers without having to close madmapper and reopen with the socket either in or out as desired. I've tried setting the output on the madmapper settings to either headphones or built in speakers but makes no difference.
    Outside of madmapper...the audio works exactly as expected...comes out the heaphone socket when it's plugged in...and comes out of speakers when unplugged.
    A bug perhaps?? anyone else have this problem??
    Re: problems playing back audio
    by Pierre Guilluy » Mon Oct 31, 2022 11:45 am
    Does the problem always happen loading the same audio files, or is it random?
    Please share the audio files you have problems with on the support: support@garagecube.com
    Are you working on Mac or Windows?
    If you're working on Windows, are you using DirectSound or ASIO?
