LED Scanner Falcon Controller
  • rna_parts
    by rna_parts » Wed Nov 02, 2022 7:49 am
    Help. Using the LED Scanner works great using our Light O Rama controller. Hower we are trying to do the same thing with a falcon controller and something weird happens. the LED scan works great, it appears that each dot is captured right where it is supposed to be, however, when you play a test Line slowly over the newly scanned pixels, they are randomly all over the place. it makes no sense. Any ideas?
    Re: LED Scanner Falcon Controller
    by mad-matt » Fri Nov 04, 2022 3:06 pm
    No idea. You can verify the data being sent in the DMX Monitor inside MadMapper.
    You can also try to deactivate synchronization packets ("Enable universe synchronization" in preferences / DMX Output). Some devices don't handle it properly.
    Are you sending with ArtNet or sACN ?
Users browsing this forum: No registered users and 52 guests
