Bug in quad toggle while cueing
  • play.vj
    by play.vj » Thu Dec 15, 2022 6:43 pm
    If i create some cues with two quads, and than add a cue with a third quad the on off toggle of the quad is not respected in previous ques that were created with only two quads. If i trigger one of the "older" cues the third quad is on. Logic would say it is off since it was not there when the cue was created. Updating the old cue affects the new cue, where the quad toggle is set to off instead of on. This happens on version 5.0.6. windows 10
    Re: Bug in quad toggle while cueing
    by mad-matt » Mon Dec 19, 2022 11:11 am
    No. Cues just send values stored in the cues to the project parameters. If you want this behavior (hiding surfaces not stored in the cue), you have to use "scenes".
  • play.vj
    by play.vj » Thu Dec 29, 2022 10:11 am
    Ahh, ok than. Will test this and try to figure it out. Thanks!
  • anden345
    by anden345 » Mon Jan 16, 2023 6:54 am
    I will try them and will check if it works well or not
    ovo
