layer opacity problem
    g4jon
    by g4jon » Thu Jun 19, 2008 7:53 pm
    Hello
    As I reduce layer opacity on the slider (move from left to right) in any layer. The opacity of that layer goes black after 3/4 of the way along. This has just started after installing the lastest version of m8. Obviously it should not do this.
    system config:
    Mac OS 10.5.3
    Model Name: Power Mac G5
    Model Identifier: PowerMac7,2
    Processor Name: PowerPC 970 (2.2)
    Processor Speed: 2 GHz
    Number Of CPUs: 2
    L2 Cache (per CPU): 512 KB
    Memory: 3.5 GB
    Bus Speed: 1 GHz
    QuickTime Player:
    Version: 7.5
    Last Modified: 16/06/2008 11:53
    Kind: Universal
    g4jon
    continued from above
    by g4jon » Thu Jun 19, 2008 8:24 pm
    and this is my graphics card!
    NVIDIA GeForce 6800 Ultra DDL:
    Chipset Model: GeForce 6800 Ultra
    Type: Display
    Bus: AGP
    Slot: SLOT-1
    VRAM (Total): 256 MB
    Vendor: NVIDIA (0x10de)
    Device ID: 0x0040
    Revision ID: 0x00a1
    ROM Revision: 2119
    by ilan » Wed Jul 02, 2008 12:13 pm
    Try disabling all modules and see if the problem persists. If the problem goes away with shutting down all of the modules then progressively turn on modules to find out which module might be causing the problem.
    Also... what kind of codec are you using on your clips?
    g4jon
    problem still ongoing
    by g4jon » Wed Jul 02, 2008 3:52 pm
    Hello
    problem still ongoing. Turned off all modules and it still does this. using photo-jpeg codec. This does not do it on my g4 powerbook using Tiger. I am using Leopard on the G5. I have trashed the preference file, it still does it. Perplexed!!!!
    g4jon
    SOLVED
    by g4jon » Wed Jul 02, 2008 6:51 pm
    Problem was with my "Blank Master" doc that I programmed all my midi info into. This some how was corrupted I presume. I will now have to remap my midi controller to M8 again.
