Playing a specific clip at startup
  • augenblick
    by augenblick » Tue Jan 10, 2023 1:05 pm
    Hi
    I have a problem with a show that contains 16 films and 30 pictures that can each be triggered via OSC from an iPad.
    Whenever the computer is powered on, madmapper starts automatically and a specific video is played.
    That video is in the Cue Row 1 on Column 7.
    And I can't figure out why I can't change it to something else.
    In my case it should be Video06 in Cue Row 2 on Column 6.
    How would I do this?
    Braunwald_V18.zip
    Braunwald Madmapper Show
    (17.61 KiB) Downloaded 327 times
  • augenblick
    Re: Playing a specific clip at startup
    by augenblick » Tue Jan 31, 2023 10:50 am
    I just got an update from the garageCube team that this behaviour will be fixed in the upcoming 5.2.3 and should then behave as intended.
    The workaround I found in the meantime is that you have to send the clip you want to play first down to the bottom of the OSC list.
    As soon as I change that to another clip this will become the one that plays automatically on startup.
