remote gui
    mipmarple
    remote gui
    by mipmarple » Mon Jan 16, 2023 2:59 pm
    :idea: Idea :idea:
    Having a remote gui / client application on a notebook to control a madmapper instance running on a master machine
    I think everybody knows the problem messing around with long cables, video transmitters or remote software for setting up a mapping where you have sit right in front of the mapping but all projectors are far away.
    Windows remote desktop is quick, for free, but does not allow controlling external monitors.
    TeamViewer or VNC usually is the way to go but brings its quirks.
    So you would have to setup the outputs on the master machine.
    Then you could use a lightweight computer connected via wifi to setup everything while walking around.
    Re: remote gui
    by franz » Wed Mar 22, 2023 5:34 pm
    +1
    but that's a lot of work.
    On PC I suggest you try out Anydesk, it is fast and reliable, much better than TeamViewer IMHO
  • timbrass
    Re: remote gui
    by timbrass » Tue Aug 15, 2023 10:52 pm
    I use "Remote Desktop" where a thin client device is connected close to a set of ILDA cabled Lasers and publishes a private wifi SSID (no internet required), so it works for Madlaser but not for a connected projector. I spent ages trying to work out if there was a way to get a copy of MM on the thin client device to send output to the VGA port on the same device, but it appears impossible.
  • kevw8504
    Re: remote gui
    by kevw8504 » Fri Jan 19, 2024 11:08 pm
    I use chrome Remote Desktop all the time for most of our installations. This seems to work reliably and from my laptop and iPhone both. good free solution for remote management.
    Kevin Winkler
    Founder / Chief Innovation Officer
    812-444-9515
    kevin@blockhouse.media
  • TheYouth
    Re: remote gui
    by TheYouth » Sun May 19, 2024 9:25 pm
    Had this idea years ago... Sadly nothing new on this... :-(
    https://forum.garagecube.com/viewtopic. ... 98&p=58992
    Re: remote gui
    by franz » Mon May 27, 2024 9:55 am
    we're working on Timelines at the moment.
    Once released, we might work on a remote app
  • kevw8504
    Re: remote gui
    by kevw8504 » Fri Sep 13, 2024 1:59 am
    Love to hear it, absolutely cannot wait for timeline feature as I have a massive installation with 38 projectors that I need something like this. BTW Franz please check my reply to your private message :wink:
    Kevin Winkler
    812-444-9515
