Ping Ponk ???
  • fekril
    Ping Ponk ???
    by fekril » Tue Feb 07, 2023 1:57 pm
    C quoi Ponk ???
    ça sert a quoi ?
    ça s'installe comment ?
    on s'en sert comment ?
    une petite demo quelque part peut-être ?
    Re: Ping Ponk ???
    by franz » Mon Mar 06, 2023 11:55 am
    un framwork pour envoyer des path depuis touch/open frameworks vers MM, pour le laser.
    La doc est sur github
  • TimRedfern
    Re: Ping Ponk ???
    by TimRedfern » Mon Mar 27, 2023 9:30 pm
    I too am wondering how to find PONK
    I downloaded the SDK from github and I compiled a PONK sender
    Now, how to receive it in MadLaser? I've installed the demo of MM/ML 5.2.4 but there's no mention of PONK in the documentation. I've looked through every menu and every place it would make sense to set up the receiver (I think). Search for PONK in the help menu returns nothing.
    Can you help me find PONK? ;-)
  • timbrass
    Re: Ping Ponk ???
    by timbrass » Mon Aug 14, 2023 10:42 pm
    The Ponk software for TouchDesigner is at https://github.com/madmappersoftware/Ponk but I can't work out how you install it!
    Re: Ping Ponk ???
    by mad-matt » Wed Sep 13, 2023 10:00 pm
    I had not seen this post sorry. In the repo you'll find a Touch Designer sample project (here: https://github.com/madmappersoftware/Po ... %20Project)
    If you open it it should start streaming data and a new "Live Source" should appear in MadMapper media bin.
  • Luca Ferro
    Re: Ping Ponk ???
    by Luca Ferro » Mon Dec 23, 2024 5:02 pm
    Hi
    looks an awesome plugin, why did I dicover it only now?
    but i'm writing here because i'm facing some issues.
    Touch is crashing a lot. it happens if I substitute the input op, if I drag in the tox, if the sop become too complex....
    Then opening the textured example my laptop fans go crazy and blow hard.
    any suggeston? thanks a lot
  • danisa
    Re: Ping Ponk ???
    by danisa » Wed May 07, 2025 11:27 am
    Ponk est une application de contrôle à distance. Elle permet de déclencher des cues, des scènes ou des effets dans MadMapper (et parfois d'autres logiciels) via le réseau local ou des entrées externes comme OSC, MIDI. Worldguessr
    Re: Ping Ponk ???
    by mad-matt » Fri Jul 18, 2025 9:52 am
