MadMapper 5.2.3. Release
    by MADben » Thu Feb 09, 2023 1:05 pm
    Dear mappers,
    You can download the freshly released MadMapper 5.2.3 directly from the MadMapper website / user account / downloads
    The free update for v5 users brings a couple of nice additions, MadLight improvements and multiples fixes,
    MM 5.2.3 Release Notes
    ADDITIONS
    + Added a menu to access the log files
    + Added a preference to select workspace path at startup
    IMPROVEMENTS
    * MadLight Recorder: set the Sync Audio to DMX on by default
    * MadLight Recorder: warn about unsupported filenames while exporting to the MiniMad
    FIXES
    - Renamed the material instance when duplicating it in the Code Editor
    - MadLaser: Fixed output smoothness when using multiple Helios on macOS
    - Fixed OSC Controls being triggered when reloading a project (ie starting a cue...)
    - Fixed possible deadlock when quitting the application
    - Fixed media colors burning with live-steam on Windows
    - Fixed Master Color widgets (Video/Laser/DMX) showing invalid color after restarting the app
    - Fixed Calendar Scheduler in some cases (UTC handling)
    - Fixed YUVA 4444 P12 pixel format handling with FFMPEG (invalid colors)
    - Fixed possible issue with mouse interactions in preview panels after loading a project on macOS
    Enjoy!
    The MAD Team.
Users browsing this forum: No registered users and 63 guests
