How to make a single property reactive to sound
  • steppenwolf
    by steppenwolf » Mon Feb 20, 2023 2:47 pm
    I come from Lightform. There, once the project has been published, you can make layers reactive to sound, by property (brightness, contrast, saturation, etc.). For example: a golden texture shines more or less according to the volume of the music; a texture wiggles more or less according to how much noise the audience makes.
    In MadMapper, is there a simple way to make the value of a media reactive to audio input? I guess that changing contrast is not the same as applying an effect such as wiggling, but the principle may be the same.
    Thank you very much in advance.
    Re: How to make a single property reactive to sound
    by mad-matt » Wed Feb 22, 2023 10:55 am
    For sure, just right click the parameter widget (slider...) and choose Add Control / Audio / Amplitude (or bass, treble...)
    Matthieu - MM team
  • steppenwolf
    by steppenwolf » Fri Feb 24, 2023 2:16 pm
    Matthieu - MM team
    Thank you very much Matthieu, I'm a rookie ;)
