pixel streched effect
  • laubaine
    by laubaine » Thu Feb 23, 2023 4:52 pm
    Hi
    There's an "effect" I love doing with madmapper up to version 5.1, is the pixel stretched effect. When a content is smaller than the quad, madmapper fill up the rest with the last pixels and stretched till the end of shape.
    With the new version 5.2 it doesn't do anymore :(
    I use madmapper also for vjing. That's why.
    Is there another way to do that?
    I've attached an image from madmapper 5.1.6, with the effect I'm saying
    and another image with madmapper 5.2.3, hidding the stretched pixels.
    Thanks for your help
    Screenshot 2023-02-23 at 14.38.12.png (70.58 KiB) Viewed 2558 times
    Screenshot 2023-02-23 at 14.37.39.png (90.1 KiB) Viewed 2558 times
    Re: pixel streched effect
    by mad-matt » Thu Feb 23, 2023 6:12 pm
    That's because in most case you don't want this effect but I just pushed an Surface 2D FX in the online library called "Clamp To Edge" that includes color controls and does the desired effect. So just install it and you'll get what you want!
  • laubaine
    by laubaine » Tue Feb 28, 2023 10:57 pm
    Merci Matt. Trop sympa. That's exactly what I want and that no ones wants in his mapping...
    Thanks a lot. :D
