MiniMad with Advatek PixLite issues
  • max-light
    by max-light » Sun Mar 05, 2023 1:36 pm
    Just have problems to play sequences from MiniMad to Advatek PixLite. Advatek PixLite 4 MKII works fine with MadMapper, I can play all sequences from MadMapper. But once I transfer my sequences to SDCard, connect MiniMad to PixLite, it doesn't work. I tried a lot of combinations...
    This is my setup:
    PixLite static IP: 2.0.0.2 with 255.0.0.0 mask
    MadMapper PC IP: 2.0.0.1 with 255.0.0.0 mask
    MiniMad IP setting (from "MadLight Recorder" tab in MadMapper -> export to MiniMad -> network configuration->manual): 2.0.0.3 with 255.0.0.0 mask. (I tried also 2.0.0.1 with 255.0.0.0 like a PC setting but still doesn't works)
    Then insert SDCard to MiniMad, disconnect ethernet cable from PC and connect it to MiniMad, then power on a MiniMad...nothing
    A step-by-step manual of how to get this all to work would be greatly appreciated...
    Re: MiniMad with Advatek PixLite issues
    by Pierre Guilluy » Mon Mar 13, 2023 10:49 am
    This has been fixed in MadMapper 5.2.4.
    Sorry for the inconvenience.
