Stepper Motor Control
  • marcellm
    by marcellm » Wed Mar 15, 2023 10:21 pm
    Hi, I love that MM has Servo motor control, and have used it successfully in a piece, however is it possible to have stepper motor control? Perhaps a way to translate servo control to stepper motors?
    Thanks, Marcell
    Re: Stepper Motor Control
    by mad-matt » Thu Mar 16, 2023 5:16 pm
    It might not be complicated to send OSC from MadMapper (OSC Out Module) to an Arduino. I did it without problems a while ago. There's an official OSC library in Arduino Studio. But you have to program what you want to do on stepper based on that.
    You should easiely find resources for doing it
  • marcellm
    by marcellm » Tue Mar 21, 2023 2:43 am
    Thank You for that info. I will try out the OSC integration.
    Marcell
