MadMapper 5.3 BETA 2 release
    by MADben » Wed Mar 22, 2023 6:05 pm
    Dear mappers,
    We just released MadMapper 5.3.0 BETA 2 with nice additions as well as Blackmagic performance and Expert mode improvements,
    You can ownload it directly from your user account on the MadMapper website,
    Any feedback is welcome!
    Enjoy !
    MM 5.3.0 Beta 2 Release Notes
    ADDITIONS
    + Added Output settings to position a Quad surface precisely in pixels
    + Added menu Edit / Cut
    IMPROVEMENTS
    * Improved performance of Blackmagic video capture with ARGB pixel-format
    * When Laser expert mode is enabled, show "RGB Samples" settings on Laser Lines / Laser Text to setup the precision of the color/position sampling
    FIXES
    - Fixed issue when re-authorizing MadMapper without internet connection
    - Fixed a potential issue when changing pixel-format on Blackmagic video-capture cards
    - Update a Scene was not updating modules settings
    - Fixed possible issue when deleting a Video Output
    - Fixed sending sACN multicast on localhost on macOS
    - On Apple M1 < M1 Max, using a GPU intensive shader could lead to low view refresh
    - Fixed some FX (ie Gaussian Blur...) on internal video loopback
    - Fixed flickering of fixtures when using internal Video loopback
    - Fixed video lines with texture mode "Match Output Geometry"
    - Fixed DMX Fixtures compatibility with some materials defining PI
    - Fixed uncueing a module by pressing backspace on module in edit cues mode
    (a MadMapper 5 license is required to use this Beta version)
    The MAD Team.
