madart file format
  • pigabo
    madart file format
    by pigabo » Tue Mar 28, 2023 4:46 am
    Hey I want to read in the madart file to get the Universes and they're relating IPs in a program of mine.
    Its CPP
    But I can't wrap about how the config file is structured.
    I do some weird memcompare things but it feels rigged
    Could you provide me some Information how the file is structured? That would be great
    Re: madart file format
    by mad-matt » Tue Mar 28, 2023 10:55 am
    Just use ".csv" as file extension it will make a CSV file
  • martenbiehl
    by martenbiehl » Tue Feb 04, 2025 4:20 pm
    Hi!
    This doesn't seem to work anymore. If I open it in VS Code I can see lots of binary characters and I also cannot export it into Excel (no matter which import settings). Any pointers?
    Best
    Marten
  • martenbiehl
    by martenbiehl » Thu Feb 06, 2025 4:56 pm
    For other people looking for this, I got an answer from support:
    It works, you "just" have to export the file with a .csv ending. So when exporting name the file that way and it works.
  • angelaevans8x
    by angelaevans8x » Thu May 08, 2025 4:23 am
    Mapquest Directions Have you captured a hex dump of the file to look for repeating patterns or magic numbers?
  • martenbiehl
    by martenbiehl » Fri Oct 10, 2025 5:02 pm
    sorry, I only saw your message now. It does work, MadMapper seems to take the export format from the file ending. When naming the file .csv it exports it as text file, so I never looked at the actual binary data too closely.
    Best
    Marten
Users browsing this forum: Baidu [Spider] and 77 guests
