Madmapper 4.2.1 crashing for unclear reason
  • decoye
    by decoye » Tue Apr 11, 2023 11:36 am
    this morning im running into a strange problem.
    im loading my project from last night, it tells me it cant find 2 files and that it wants help to find the videos.
    i locate both files, on the second video, the moment i press choose in the browser madmapper crashes.
    does not say what causes it boot up normally otherwise.
    Both files are located on C:// in a dropbox folder.
    Anyone have this before?
    Re: Madmapper 4.2.1 crashing for unclear reason
    by mad-matt » Tue Apr 11, 2023 1:33 pm
    Not a known issue. I suppose it has been fixed inbetween. Are you sure your dropbox file is avialable offline ? (right click the file / Dropbox / Make available offline, without it file size may be 0 bytes, just a link)
  • decoye
    by decoye » Tue Apr 11, 2023 7:37 pm
    Yes 100% sure.
    I looked deeper into the problem.
    No matter what I'm storing it crashes. Even newly created files with one png in it.
    I was looking at the logs, it seems the last entry it writes before it crashes is.
    "Registered to unknown unknown unknown"
  • decoye
    by decoye » Tue Apr 11, 2023 8:23 pm
    This is the last part of the log file when it crashes.
    INFO 11/04 12:45:13.350 Removing control device: /osc/MadMapper
    INFO 11/04 12:45:13.351 Deleting Control Device MadMapper
    INFO 11/04 12:45:13.351 Removing control device: /dmxin/ArtNet In
    INFO 11/04 12:45:13.351 Stopping ArtNet Interface WLAN 2 - 192.168.1.107
    INFO 11/04 12:45:13.372 Deleting Control Device ArtNet In
    INFO 11/04 12:45:13.372 Removing control device: /dmxin/sACN In
    INFO 11/04 12:45:13.372 Deleting Control Device sACN In
    INFO 11/04 12:45:13.372 Removing control device: /audioin/MadMapper Output
    INFO 11/04 12:45:13.372 Deleting Control Device MadMapper Output
    INFO 11/04 12:45:13.372 Removing control device: /audioin/Headset Microphone (Oculus Virtual Audio Device)
    INFO 11/04 12:45:13.372 Deleting Control Device Headset Microphone (Oculus Virtual Audio Device)
    INFO 11/04 12:45:13.372 Removing control device: /audioin/Default Device
    INFO 11/04 12:45:13.372 Removing control device: /io/ableton_link
    INFO 11/04 12:45:13.373 Deleting Control Device Ableton Link
    INFO 11/04 12:45:13.373 Removing control device: /dmxin/Dmx Input
    INFO 11/04 12:45:13.373 Deleting Control Device Dmx Input
    INFO 11/04 12:45:13.373 Removing control device: /midiout/all
    INFO 11/04 12:45:13.373 Removing control device: /midiin/all
    INFO 11/04 12:45:13.373 Removing control device: /key/all
    INFO 11/04 12:45:13.373 Deleting Control Device key
    INFO 11/04 12:45:13.373 Releasing NDI Service
    INFO 11/04 12:45:13.373 MadMapper - BWUQ licensed to Unknown Unknown - Unknown
    INFO 11/04 12:45:13.373 Deleting Control Device Default Device
    INFO 11/04 12:45:13.373 Deleting Control Device MadMapper
    ======== Log ended
    by mad-matt » Fri Apr 14, 2023 12:34 pm
    That's the log of a clean application exit. But "Registered to unknown unknown unknown" means your registration is not correct, please deactivate and reactivate MadMapper and let me know if it solves.
  • notedguiltless
    by notedguiltless » Tue Oct 24, 2023 5:36 am
    That's the log of a clean application exit. But "Registered to unknown unknown unknown" means your registration is not correct geometry dash world please deactivate and reactivate MadMapper and let me know if it solves.
    Why does the Registered to unknown error occur?
