Mirrorhead dynamic Projection institute ?
    pele2010
    by pele2010 » Wed Apr 19, 2023 9:15 pm
    Hey,
    is it possible to use the mirrored of the dpi (dynamic projection institute) with madmapper and control it?
    That would be awesome ....
    Thanxs Peter Lund
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
    Re: Mirrorhead dynamic Projection institute ?
    by mad-matt » Fri Apr 21, 2023 9:54 am
    If it's DMX controllable you can of course. You can use the same controls to change the position in a media so moving the head moves content at the same time, but that has to be programmed, there is no existing magic and anyway it should be adapted to the environment.
Users browsing this forum: No registered users and 68 guests
