any DisplayLink limitation on M1?
    lego_man
    by lego_man » Thu Apr 27, 2023 6:43 am
    II recently bought a DisplayLink USB to Dual HDMI 2.0 4K device https://www.macway.com/adaptateur-displ ... i/p3041776 to improve the limited number of outputs on my M1 Pro MacBook Pro, and it seems to work pretty well.
    I just wanted to know if there are any limitations to using DisplayLink devices with MadMapper?
    Re: any DisplayLink limitation on M1?
    by mad-matt » Thu Apr 27, 2023 9:04 pm
    No. But there is a hardware limitation on the number of outputs you can use that you should find in MacBook specifications.
    lego_man
    by lego_man » Tue May 09, 2023 2:11 pm
    My macbook pro M1 has an hardware limitation of 2 monitors,
    with this display link adaptor I'm able to connect 4 output (I've only tested with 1080p resolution)
  • oopsaloop
    by oopsaloop » Wed Sep 27, 2023 5:14 pm
    Hi Yannick!
    Any news about this setup? What are your experiences?
    I am looking for a similar setup with a macmini M1.
    Will madmapper work with a Displaylink adapter? Does it recognize all 3 HD-outputs (or even 4)?
    Thanks in advance!
    Cheers!
    by mad-matt » Sun Oct 01, 2023 11:32 am
    For info I used my MacBook Pro M1 Max with three projectors 1920x1200 60Hz using simple USB C - HDMI adapeters + my laptop screen without issues.
  • Firefly_199x
    by Firefly_199x » Tue Dec 12, 2023 4:47 am
    There are some limitations. Examples: You might experience dropped frames or lag,wordle unlimited especially with demanding visuals or high resolutions. The color space might be restricted compared to native display outputs.
