How do I cue audio reactivity?
  • steppenwolf
    by steppenwolf » Sun Apr 30, 2023 11:31 am
    I have set some reactive lights. However, I am being unable to drag and drop such audio controllers into cues, so I can decide when the lights will be audio reactive. Is there a way to switch audio reactivity on and off, and to do it light by light?
    Re: How do I cue audio reactivity?
    by mad-matt » Tue May 02, 2023 6:18 pm
    You can use a "Controls Combiner" module. This one can have input 1 with a fix value, input 2 controlled by audio input, and you can cue the "Mode" to switch from input 1 to input 2 with cues. Then assign the Controls Combiner output to your setting
  • steppenwolf
    by steppenwolf » Thu May 04, 2023 12:18 am
    Thank you!
