MiniMad Latency
  • dnelson7
    MiniMad Latency
    by dnelson7 » Mon May 01, 2023 6:45 pm
    Hello All!
    I'm a new MiniMad user and I love them! Currently running four minimads on four 55' Samsung 4K tv's as a video wall in an art gallery. They work really well for 3-4 hours but then they start to get out of sync. Do I need a better network switch or is this simply a limitation of the hardware?
    Thx
    Re: MiniMad Latency
    by MADben » Tue May 02, 2023 5:33 pm
    there's no such limitation with the device, it could be the network switch, your medias, your export settings.
    Feel free to write to support@garagecube.com
    Re: MiniMad Latency
    by franz » Tue May 02, 2023 5:45 pm
    maybe the heat is the problem. Try to put the 4 minimads in a well ventilated place, with regular cool air, to see if it helps.
