(vs) Media Sequencer (layer) : a Timeline like module
  • Lupin
    by Lupin » Wed Jun 25, 2008 3:39 pm
    Hello, i just released a new module to trigger media in a sequence. you can choose the number of patterns you wanna play.
    It's not a timeline but you can play movies sequentially:
    to play every frames push the wait movie button.
    enjoy!
    here's a preview of the module in edit Mode
    wygiwys
    by wygiwys » Wed Jun 25, 2008 5:34 pm
    Very nice!
    Thank you very much!
    What You Get Is What You See
    WYGIWYS.tv
  • incuf
    by incuf » Fri Jun 27, 2008 2:12 am
    Very Nice!!!! sync to BPM would be great too!!
    cheers
    good work!
  • Lupin
    by Lupin » Fri Jun 27, 2008 3:01 am
    sure in the next release
    Gregg Normal
    by Gregg Normal » Tue Jul 01, 2008 1:26 pm
    Thanks for this its ace.
  • mowgli_uk
    by mowgli_uk » Tue Jul 01, 2008 4:41 pm
    We love you!
  • videomasta
    by videomasta » Tue Jul 01, 2008 6:37 pm
    great module. but there is a bug in the "wait movie" option.
    it waits 1 second on the end of every movie before it jumps to the next movie.
    you see a still image of the last frame ...
    the timed switch works realy great. thanx a lot for this module !
  • Lupin
    by Lupin » Wed Jul 02, 2008 1:16 pm
    it's not a bug ,the module is buikt ont hte structure of the current slideshow module. it only wait the end of the movie regardless of the time. for instance if the movie leduration is 5 seconds, and your timer is set to 6 at then end of the movie it will wait for one second, but if you set the timer to 1 second andthe module will wait for the end of the movie before going to tne next media on the list. there are no event in modul8 scripts to yell at the end of a movie.
  • videomasta
    by videomasta » Wed Jul 02, 2008 10:56 pm
    ahh, i see. i did not get it with the wait time ...
    perhaps this code helps detecting a loop.
    regrettably the begining .....
    (put it in the periodicalEvent section)
    # Ensure variable is defined
    try:
    theOldMovieDuration
    except NameError:
    theOldMovieDuration = None
    if theOldMovieDuration is None:
    theOldMovieDuration = 100000
    theMovieDuration = modul8.getValue('direct_layer_media_timePositionSec', 1 )
    if (theOldMovieDuration > theMovieDuration):
    print "________________loopHasStarted: "
    theOldMovieDuration = theMovieDuration
  • Lupin
    by Lupin » Fri Aug 08, 2008 11:40 pm
    i'll try it
    thanks it's a good idea
  • samulj
    Re: (vs) Media Sequencer (layer) : a Timeline like module
    by samulj » Sun Oct 26, 2014 4:21 pm
    This is great! Any plans on implementing the BPM?
  • Kasztanek
    by Kasztanek » Fri Nov 21, 2014 2:06 pm
    It's great ! :D
  • skinpenthar
    by skinpenthar » Fri Feb 27, 2015 7:10 am
    it only wait the end of the movie regardless of the time. for instance if the movie leduration is 5 seconds, and your timer is set to 6 at then end of the movie it will wait for one second, but if you set the timer to 1 second andthe module will wait for the end of the movie before going to tne next media on the list. there are no event in modul8 scripts to yell at the end of a movie.?
    We are the leading the world in providing best Testking prince2 certification and Testking Six Sigma Certification prep solutions. Our incredible offers for nova and examsheets gedare accessible at Florida National University is very rare in IT world.
