6 channel Audio output from Madmapper on Mac?
    donuan
    by donuan » Wed May 24, 2023 4:23 pm
    Hi guys,
    Did anyone have any luck with getting multi channel audio out from madmapper on mac?
    I tried exporting a .mov, prores422 with 6 channels but I'm not getting that to work.
    Any other ideas?
    or recommendations for a light weight software bridge?
    Thanks a bunch!
    Spects:
    Mac Book pro 2019, 16inch, 2,4 GHz 8-Core Intel Core i9, 64 GB 2667 MHz DDR4,
    Mac OS 10.15.7 (Catalina)
    Audio interface: Behringer UMC1820.
    Re: 6 channel Audio output from Madmapper on Mac?
    by mad-matt » Wed May 31, 2023 9:57 pm
    There should be no problem with 6 channels.
    First, did you activate "Enable Hardware Acceleration" in the movie setting in MadMapper ?
    If so, audio is directly handled by Apple AVFoundation, and audio is directed to the audio device selected in your macOS.
    If not, audio is handled by MadMapper. ProRes are per default set to use AVFoundation on macOS because it does hardware decoding, but it's working perfectly with FFMPEG.
    If you play in QuickTime, does it go to all 6 channels ?
  • piotrus04
    by piotrus04 » Fri Sep 06, 2024 1:53 pm
    Hi Matt , donuan,
    Precisely the ffmpeg command is
    ffmpeg -i "videofilepath" -i "audiofilepath" -c:v copy -c:a copy -map 0:v:0 -map 1:a:0 new.mov
    We use that command to concatenate sometimes heavy multitrack audio with the related video file.
    The command means :
    copy the video and audio in one file and map the video on track 0 and audio (interlaced) in track 1.
    Output it as a file named new.mov
    And do as Matt commented , hardware acceleration. If you are on Mac, you will have to select the same audio driver in OS X than in
    Madmapper. If I remember well, it doesn’t work well if you do it by other means.
    Of course , first, Use ocenaudio audacity or any free audio tool to manipulate the audio stems and output it as a single interleaved multitrack audio file.
    Best
    Pierre
  • piotrus04
    by piotrus04 » Fri Sep 06, 2024 1:54 pm
    Hi Matt , donuan,
    Code: Select all
    The command means :
    Best
    Pierre
