MadMapper 5.3.2 Release
    by MADben » Tue Jun 06, 2023 4:58 pm
    Dear mappers,
    The 5.3.2 version is now available with many improvements and bug fixes,
    The update is free for v5 owners, download it directly from your user account on the MadMapper website :)
    MM 5.3.2 Release Notes
    IMPROVEMENTS
    * Demo version: show info text when in laser output blackout (demo limitation)
    * Handled "restart" / "reset" in all ISF generators (damper, linear filter, ease filter...)
    * Ableton Link as Global BPM source: added an option to allow MadMapper to change BPM or not
    * Optimized changing cue bank when there are hundreds of cues
    * Restored Engine Speed at application startup
    FIXES
    - Fixed a few issues when using multiple cue banks (with undo/redo and when deleting cued objects - ie surface, media, module...)
    - Fixed possible issue with MadRouter to Enttec Pro/Mk2 on macOS
    - Fixed possible issue in BlackMagic output if starting device failed (used by another application ?)
    - Better handling of errors when iterating over Spout sources
    - Fixed an issue when using MadLight recorder with ArtNet as input and no ethernet devices
    - Fixed Laser Text with stick fonts on Windows
    - Fixed using FX with mipmapping on video loopack sources
    - MadLaser: fixed possible issues when combining laser quad mask & laser output mask
    - MadLaser: fixed showing ILDA points on Windows
    - Fixed possible issue triggering cue changing a Material with Render To Texture
    - Fixed possible issue with cues when starting a Surface FX and changing its parameters
    - MadLight: on Windows, in some conditions, not all network adapters were available
    - When restarting an FFMPEG movie from a cue, last decoding frame could show up first (now always starts on first loop frame)
    The MAD Team
