. question about new keyword in 2.5.5
  • anomad
    by anomad » Thu Jun 26, 2008 4:48 am
    . how do i use 'direct_layer_media_stepFrame' ?
    . can i map a midi event to a button in a module and use direct_layer_media_stepFrame to have it step through a movie frame by frame? would i set the movie speed to 0 to use it?
    . what is the correct syntax? i have a button that sends a nextFrame message, and the code i'm using looks like this:
    if msg=='nextFrame' :
    if param['value'] == 1.0 :
    modul8.setValue('direct_layer_media_stepFrame',0)
    .(the ',0' means use the current layer, right?) and that doesn't seem to do anything.
    . thanks in advance!
  • Lupin
    by Lupin » Thu Jun 26, 2008 2:34 pm
    no it's the number of frames you wanna step
    ex:
    in your case it would be be like this for the current layer :
    Code: Select all
    if msg == 'nextFrame' and param['value']: modul8.setValue('direct_layer_media_stepFrame',1,0)
  • anomad
    by anomad » Fri Jun 27, 2008 3:46 am
    . thanks!
    . that fixed it! and i found you can use negative numbers to skip backwards -- very nice
    . (btw, i'm a big fan of the modules you've posted! )
  • Lupin
    by Lupin » Fri Jun 27, 2008 12:03 pm
    thx, i also wanted to write a module to do a step by step. by the way i jsut added a module :
    (vs) Frame Stepper (layer)
    enjoy
  • anomad
    by anomad » Sat Jun 28, 2008 4:30 am
    . very nice! pretty much what i was looking to do.
