LED's dead
  • Paulyo
    LED's dead
    by Paulyo » Mon Jun 26, 2023 9:42 am
    Hi, please can someone help.
    I've just moved city and up-packed my LEDs for a gig on Friday.
    I've set them up with MadMapper – latest version – and – USB to dmx – but the LEDs are not responding and appear to be dead.
    Is there a way of checking or resolving this issue? What am I missing or I am setting-up wrong?
    Thanks in advance
    Paul
    Re: LED's dead
    by MADben » Tue Jun 27, 2023 10:30 am
    Hi Paul, make sure your controller is properly selected in the Preferences / DMX output and nothing selected in DMX output. Make sure you select the proper fixture profile, double-check your connections, switch cables, power supply, etc. if you can and run a test with only a single bar and the minimum connectivity
  • Paulyo
    Re: LED's dead
    by Paulyo » Thu Jun 29, 2023 5:40 am
    Thank you. I’ve double checked all the connections and preferences and now the single 0.5m is lighting and working fine.
    I have also connected the other 15bars and they too light fine and work as expected.
    Thank you for the advice :-D
