MadMapper 5.4 BETA available
    by MADben » Thu Jul 27, 2023 4:43 pm
    Dear mappers,
    MadMapper 5.4 is now available for BETA testing!
    The upcoming free update brings performance goodies :
    The control surface module - it lets you trigger scenes & cues and navigate your current cue bank with your MIDI controller (for now AKAI Professional APC mini mk2, AKAI Professional APC40 mk2 or Novation Launchpad MK2),
    The stream deck plugin - it enables you to trigger scenes & cues and to control your project parameters using Stream Deck devices,
    Lottie animations support for MadLaser!
    IDN (ILDA Network) DAC support for MadLaser,
    The Note Editor to write some notes that are saved in projects,
    The Reload file menu entry for file-based media.
    If you have a bug to report or if you want to share feedback, feel free to write to support@madmapper.com
    Don't forget that this is a BETA version, so use at your own risk if you're in production.
    This BETA version is free and requires a MadMapper v5 active license. The installer file is available https://madmapper.com/myaccount/downloads.
    MM 5.4 Beta Release Notes
    ADDITIONS
    + Control Surface module for triggering cue banks with colored pads - compatible with AKAI APC40 mk2, AKAI APC Mini mk2 & Novation LaunchPad Mk2
    + Stream Deck plugin to trigger MadMapper scenes, cues and parameters from StreamDeck seamlessly (Stream Deck support must be enabled in Preferences)
    + Notes Editor: added a new editor to write some notes that are save in the projects
    + MadLaser: supports Lottie animations (vector based animations exported from After Effects with Bodynmovin plugin) to create precise vector based animation for any show with a tool many people know
    + MadLaser: Added IDN (ILDA Network) DAC support
    + Osc Query now supports websocket & LISTEN / PATH ADDED / PATH CHANGED / PATH REMOVED
    + Added "Reload file" menu entry on file-based media
    IMPROVEMENTS
    * FFMPEG video player ensures first frame is shown when starting a Scene/Cue
    * MadLaser: improved laser dispatching algorithm
    * MiniMad manual remote-connection parameters are now saved for later usage
    * Allow multiple media selection and check in Export to MiniMad Video
    FIXES
    - Media Player module does no more send loop notification if media is just playing in a preview
    - Some MIDI device do not receive all MIDI feedback from MadMapper depending on the OS, so MadMapper now limits MIDI out data rate to avoid this issue
    - Fixed create video wall (was creating a laser project)
    - Audio Player module: don't restore playback position when reloading project
    - Fixed VideoWall template landscape 180°
    - Fixed media remaining black on 3D surfaces in certain conditions
    Enjoy!
    The MAD Team
    Re: MadMapper 5.4 BETA available
    by MADben » Wed Aug 09, 2023 3:53 pm
    MadMapper 5.4 BETA 2 available with, among other things, the Launchpad Mini Mk3 now supported by the Control Surface module :)
    (You can download the BETA 2 from the website / user account / downloads section)
  • danisa
    by danisa » Wed Apr 23, 2025 6:21 am
    With MadMapper 5.4 BETA 2 now supporting the Launchpad Mini Mk3 via the Control Surface module, it really opens up some tactile possibilities for mapping and performance. The Mini Mk3’s compact form and RGB feedback are a great match for triggering cues, controlling effects, or even launching presets live — all without touching the laptop.
    Escape Road
  • Firefly_199x
    by Firefly_199x » Wed Aug 20, 2025 8:36 am
    MadMapper 5.4 is a powerful update, focusing on improving performance, interoperability, and integration PolyTrack with hardware controllers.
