MM SDK or API for triggering UI elements?
  • ProjectileObjects
    by ProjectileObjects » Sun Jul 30, 2023 3:36 pm
    Is there a MM SDK or API? I'd like to configure a LoupeDeck (similar to Stream Deck) device to work with MadMapper. Examples, make a button to create a video quad / shape. Create fixtures, full screen, mute outputs, etc. I can set up buttons for the functions in MM that have built-in keyboard shortcuts, but it would be cool if I could trigger other elements in the interface.
    (The LoupeDeck supports run and applescript commands, but MM doesn't have an open AppleScript dictionary).
    Thanks
    Re: MM SDK or API for triggering UI elements?
    by mad-matt » Tue Aug 01, 2023 11:47 am
    There's no API at the moment. But a lot can be done with OSC & OSC Query. But you can't create new surfaces using OSC.
