modlul8 2.5.5 crash..
  • sbellatgroove
    by sbellatgroove » Mon Jun 30, 2008 1:14 pm
    hi there... after the new update to 2.5.5, the proram crashes every time I start it up with the second screen mounted on my macbook pro (2.2GHz, 2GB RAM).. I tried to run 2.5.4 and starts normally with no problems at all... I tried to run 2.5.5 without a second screen, and it worked normally... Is there any solution suggested?
    Thanx in advance,
    s. bell
    by vanakaru » Mon Jun 30, 2008 3:14 pm
    same here.
    while running M8 I can plug in second monitor and get full screen on it, but not when monitor is attached.
    Do you need a crash log? If so how this could be sent?
    MBP 2.4 ghz 4gb ram leo 10.5.2 qt7.5
  • sbellatgroove
    crash log
    by sbellatgroove » Mon Jun 30, 2008 3:26 pm
    here's my crash log... hope this will help me and the others.... thanx!
    http://www.visualvibeproject.com/Modul8 ... .crash.zip
    [/code]
    by ilan » Wed Jul 02, 2008 12:07 pm
    Hey guys,
    We already have a solution to this problem. We are releasing v256 soonly. Thank you for your tireless work with modul8 in helping us discover these problems and address them quickly.
    Cheers,
  • sbellatgroove
    by sbellatgroove » Wed Jul 02, 2008 12:39 pm
    Hey guys,
    Cheers,
    thanx! looking forward for v2.5.6!
  • vjjustinallen
    by vjjustinallen » Wed Jul 02, 2008 4:31 pm
    I was hoping for a solution to this problem...thanks for finding it so quick!
