MiniMad First Run- Startup error!
  • zsabbir
    by zsabbir » Sat Aug 26, 2023 2:09 pm
    Hi, done this same task on two micro sd cards, 16gb that came with it, and 128gb class 10 sd card. similar results:
    I have logged into my account, downloaded a 16gb version minimad image. used echer to intall the image. right after installation win10 asks to format it again, but i cancel.
    then i put my sd card in, then hdmi, then power.
    i receive this error. i turned it on and off, i left it for highest 30 minute. same result.
    please help, urgent
    Re: MiniMad First Run- Startup error!
    by Pierre Guilluy » Wed Aug 30, 2023 11:33 am
    I just ran the exact same procedure as you described, same OS, image size and everything, and it all worked as expected.
    Maybe your MiniMad's SD-card reader is clogged with some dust, which can result in some random errors.
    Please follow the dedicated information in the "TROUBLESHOOT" section.
  • zsabbir
    by zsabbir » Wed Aug 30, 2023 3:41 pm
    hi,
    i have received your email from support, thank you so much for that.
    have flashed the new ISO you sent, and still receiving this error, this time with a color circle in between flashes. (video emailed)
    i have cleaned my MicroSD cards, one of them is brand new though. i have cleaned the microsd slot much as possible.
    same result.
    pls help ...
    by Pierre Guilluy » Fri Sep 01, 2023 10:22 am
    Did you clean the micro-SD card slot of the MiniMad as well?
  • zsabbir
    by zsabbir » Wed Sep 06, 2023 3:30 pm
    yes i did, watching some youtube videos. no luck
    by Pierre Guilluy » Tue Oct 10, 2023 2:36 pm
    So strange, would you have a second MiniMad you could try your flashed SD-card in?
