Trace + transparency??
  • dvdan
    by dvdan » Thu Jul 15, 2004 7:11 am
    Page 30 of the Modul8 Manual reads:
    "Trace Mode also allows you to generate motion blur effects when combined with transparency."
    I am not figuring out how to do this. When I use trace, the trails that are left never fade and the screen quickly becomes overwhelmed with stale pixels. Having the traces fade over time would be great and make this a much more useful effect in my opinion. Do-able?
    Hoping to try this tomorrow nite!
    -Dan
    yves@garagecube
    Re: Trace + transparency??
    by yves@garagecube » Thu Jul 15, 2004 5:24 pm
    dvdan wrote:Page 30 of the Modul8 Manual reads:
    Well, you are right, the trace mode is not a true motion blur. However when you use it with a layer that has a very high transparency, it mays produce "some kind of" motion blur effect. Of course, it does not replace a true motion blur at all.
    Yves.
  • Guest
    by Guest » Mon Jul 19, 2004 7:18 pm
    I'd like to see trace mode come with a time adjustable 'refresh' so that the background can be cleared after a set period (usually I would use 1-5 secs but wider range the better)
    This thead just reminded me so I thought i'd post it here.
Users browsing this forum: Baidu [Spider] and 17 guests
