Maximum length between each LED bar
  • Martin Pouchard
    by Martin Pouchard » Tue Sep 12, 2023 11:33 am
    I am planning to soon buy a KIT GARAGECUBE 8 LED 1M, I saw that the cable between the Power supply and the first LED bar should not exceed 5 meters, if we respect this how much maximum length can we put between each LED BAR without having problems?
    Thanks !
    Re: Maximum length between each LED bar
    by MADben » Fri Sep 15, 2023 3:30 pm
    5m, but you can go even further. Then it depends on whether there's only one bar at "great distance" or whether all the bars are very far apart. But for a circuit, we don't recommend exceeding 20m of cable.
