MadMapper 5.4 release
    by MADben » Tue Sep 12, 2023 5:33 pm
    Dear mappers,
    It's time to have a performance blast!
    The free update MadMapper 5.4 is now available, bringing the new Control Surface module letting you trigger scenes & cues and navigate your current cue bank using your Midi controller, as well as the Stream Deck plugin enabling you to trigger scenes/cues and control your project parameters using one or several Stream Deck devices. (Check out the guides in the MadMapper Help menu).
    Your live performances will love it!
    We also added the support of Lottie animations for MadLaser and introduced a built-in note editor to write some notes that are save in the projects.
    Download the 5.4 installer file directly from the MadMapper website / user account / downloads section.
    Enjoy !
    MM 5.4 Release Notes
    ADDITIONS
    + Control Surface module for triggering cue banks with colored pads - compatible with AKAI APC40 mk2, AKAI APC Mini mk2, Novation LaunchPad Mk2, Launchpad Mini Mk3 and Launchpad X
    + Stream Deck plugin to trigger MadMapper scenes, cues and parameters from StreamDeck seamlessly (Stream Deck support must be enabled in Preferences)
    + Notes Editor: added a new editor to write some notes that are save in the projects
    + MadLaser: supports Lottie animations (vector based animations exported from After Effects with Bodynmovin plugin) to create precise vector based animation for any show with a tool many people know
    + MadLaser: Added IDN (ILDA Network) DAC support
    + Osc Query now supports websocket & LISTEN / PATH ADDED / PATH CHANGED / PATH REMOVED
    + Added "Reload file" menu entry on file-based media
    IMPROVEMENTS
    * FFMPEG video player ensures first frame is shown when starting a Scene/Cue
    * MadLaser: improved laser dispatching algorithm
    * MiniMad manual remote-connection parameters are now saved for later usage
    * Allow multiple media selection and check in Export to MiniMad Video
    * Cue Grid supports custom colors (useful with Control Surface)
    FIXES
    - Media Player module does no more send loop notification if media is just playing in a preview
    - Some MIDI device do not receive all MIDI feedback from MadMapper depending on the OS, so MadMapper now limits MIDI out data rate to avoid this issue
    - Fixed create video wall (was creating a laser project)
    - Audio Player module: don't restore playback position when reloading project
    - Fixed VideoWall template landscape 180°
    - Fixed media remaining black on 3D surfaces in certain conditions
    - Fixed issue when using popup menu / "Center" on a multi-selection of surfaces in input preview
    - Fixed possible issue in Quad geometry in some weird situations
    - Fixed a few issues in Firmata module (reconnection on project load in rare cases, unplug-replug)
    (a MadMapper 5 license is required to use this version)
    We hope you'll love it!
    The MAD Team.
Users browsing this forum: Baidu [Spider] and 38 guests
