HELP midi drum triggerig
    by vanakaru » Tue Jul 01, 2008 1:43 am
    I have a idea for a performance where large round screen is used for drumming. There would be 4 MIDI triggers in specific areas attached to the screen. I want to have a simple graphics like a growing arrow start from the point where the trigger is when hit.
    I can get MIDI from triggers to M8, but from there I am stuck.
    I could trigger different clips on selected layer. But when two clips are triggered at the same moment they freeze.
    Or I could map 4 layers to right positions on screen, but I can not switch on layers via MIDI.
    I looked through all the modules without any solution.
    I have wasted almost a day to try to figure this out and the show is in few days and I run out of time.
    Any ideas would help.
  • technomorph
    by technomorph » Tue Aug 12, 2008 4:57 am
    I use a Trigger FInger to drum style trigger my layers.
    I do have 2 modes that I set on the Trigger FInger.
    Note ON - HOLD (latch)
    and
    Note ON - OFF (momentary)
    Assign the MIDI to the little box at the very left hand side of your Layer.
    Technomorph
    by vanakaru » Tue Aug 12, 2008 11:56 pm
    In the regular interface you can assign only one active layer to MIDI. There is a Layer selection modul that will allow MIDI mapping to the layer, but with limitation.
    I succeeded my task with SET-MEDIA-TO-LAYER modul, by mapping MIDI triggers to media on different layers and setting play mode to once. Also there is a auto scale set to sound in and size to the amount that show small point.
