micromodul8 compatibility issue
  • ilan_katin
    by ilan_katin » Wed Oct 04, 2023 12:13 pm
    I am aware that the micromodul8 was not created for MM in mind but I have been using it with MM almost exclusively with not much issues. That said over two years ago I realised that MM does not respond well to the step knobs of the micromodul8. Binding the step knob to a slider control in MM and turning the step knob results in the slider locking to the far left or far right of the slider control.
    Probably not a high priority.
    I do think there could be more compatibility for MM with the micromodu8. For example with having presets available for different que banks?
    Re: micromodul8 compatibility issue
    by mad-matt » Wed Oct 11, 2023 2:23 pm
    MadMapper does handle it like in the past. Just since those buttons are "incremental", you have to setup the CC type in MadMapper Control. I think the right type is "2's Comp", but you'll find easily by trying all types.
