MadMapper 5.4.2 released
    by MADben » Tue Oct 17, 2023 11:07 am
    Dear mappers,
    We just released MadMapper 5.4.2 with, among other fixes and improvements, the support of FFMPEG 6,
    The free update (v5 owners) is available on the website : https://madmapper.com/myaccount/downloads
    Cheers!
    The MAD team
    MM 5.4.2 Release Notes
    IMPROVEMENTS
    * Laser Quad point intensity is zero by default (for auto), and can be adjusted to define a fix number of ILDA points for beams
    * Color Profile for medias can be adjusted even if information is provided (some H264 encoders donnot give correct profile, so user can adjust)
    * Updated to FFMPEG 6.0 for better video playback (good boost with AV1 codec)
    FIXES
    - Fixed possible issue when a surface FX contains multiple shaders
    - Fixed possible issue with video Test Pattern on many displays (or in very high resolution)
    - Control Surface module: Fixed scrolling using supported AKAI APC controllers' arrow keys
    - Control Surface module: Fixed APC mini Mk2 initialisation
    - Fixed masking in Laser Quad with masks attached to input
Users browsing this forum: No registered users and 64 guests
