Triger MM by a motion sensor
  • Blacksheep
    by Blacksheep » Mon Nov 06, 2023 10:04 am
    Hey Guys
    I like to trigger Madmapper by a motion sensor or a Photoelectric barrier for a standalone Installation.
    But i did not find a solution so far.
    Does anyone have an idea how to do this?
    Thank you very much
    Re: Triger MM by a motion sensor
    by mad-matt » Tue Nov 07, 2023 1:00 am
    You can use an arduino and a motion sensor. Then in MadMapper get your signal with Firmata module (there's a user guide in MadMapper menu Help / User Guides / Firmata Module)
    Using a Control with a filter "Average" will help you get rid of the noise, and the source range will let you choose the threshold over which an action should be done (start a scene or a cue maybe)
