MadMapper 5.5 BETA available!
    by MADben » Thu Nov 09, 2023 6:10 pm
    Dear mappers,
    From today you can BETA test MadMapper version 5.5 !
    We're glad to introduce:
    -the Laser Scanner! As useful as the space scanner for video,
    -a configurable auto-backup system (many of you were waiting for it),
    -the MadLight Player module (to playback your recorded DMX sequences),
    -the Starter Cue module (to start a cue right after opening a project),
    -the support of the new Hap-R codec (windows only),
    And more! You can check all the new features in the release notes below,
    The BETA is free for v5 owners, download it directly from your user account on the MadMapper website, and don't forget to hit that big red button in the app to send us your feedback !
    We hope you'll enjoy this release !
    The MAD Team
    5.5 BETA Full Release Notes
    ADDITIONS
    + MadLaser: Added Laser Scanner
    + Added an option to make snapshots of video outputs (in output inspector)
    + Added MadLight Player module
    + Added Cue Startup module to start a cue when loading a project
    + Added project backup that creates a copy of previous project state when saving
    + Added support for HapR codec (Windows only)
    + Added Import SVG & Export SVG button on masks & lines surfaces
    + Added Fullscreen button on main window
    + Added Arm Lasers item in Output menu
    + MiniMad Video: added "adjust movie framerate" advanced export setting
    IMPROVEMENTS
    * Control Surface module: separated Step parameter in two Step X & Step Y
    * Improved video playback on Windows with an audio track active and audio output is set to DirectShow
    * MadLaser: improved laser output "info" for etherdream (shows IP mistakes & recommandations)
    FIXES
    - MiniMad Video: fixed audio playback problem with some movie files
    - Fixed issue with cameras when image is bigger vertically than horizontally
    - Fixed issue when changing Lines surface thickness for hundreds of line elements
    - Fixed searching file using relative path when project was saved on Windows and loaded on macOS
