MadMapper not starting on Windows GTX 1070
  • lab_diversion
    by lab_diversion » Tue Nov 14, 2023 7:00 pm
    I had Madmapper 5.3.2 working well on my gtx 1070 latop.
    I installed a tascam US 16*08 software, together with ASIO driver.
    Now Madmapper is saying that it cannot run because of unsupported hardware :/. It says I need opengl 3 while I should have opengl 4.5 on my PC (included in my GPU driver).
    I uninstalled Tascam soft ASIO drivers, restarted the pc and still the same message.
    I uninstalled and reinstalled madmapper, tried with the latest version, but I always have the same issue. So I cannot use it anymore :/
    My GPU driver is up to date.
    I also added madmapper in my display preferences to make sure it uses the gtx GPU.
    I need to start preparing a show tomorrow, so this is quite urgent!
    See attached the message I have.
    Thanks a lot!
    Marc
    Screenshot 2023-11-14 172720.png (11.28 KiB) Viewed 8520 times
    Re: MadMapper not starting on Windows GTX 1070
    by mad-matt » Wed Nov 15, 2023 1:40 am
    Please send a support request with your log file.
    Log files on windows are located in:
      "C:\Users\your_login\AppData\Roaming\Garagecube\MadMapper\Logs\"
    You can type this in file explorer address bar:
       %AppData%\Roaming\Garagecube\MadMapper\Logs\
    Log files on macOS are located in:
    /Users/YOUR_LOGIN/Library/Logs/GarageCube/MadMapper/
    To access this hidden folder easiely you can: open Finder, choose menu Go / Go to Folder… and paste
    ~/Library/Logs/GarageCube/MadMapper/
    by mad-matt » Wed Nov 15, 2023 3:26 pm
    Do you have multiple GPUs on your machine ? Is it a laptop with an integrated GPU ? I so, you can try to disable the integrated GPU, sometimes it's possible. Or set your "Main Display" in windows display preferences on your external display.
  • lab_diversion
    by lab_diversion » Fri Nov 17, 2023 1:50 pm
    Thanks for your reply.
    So yes indeed it is a laptop.
    It has an integrated GPU. It was de activated, re-activating it solve the issue.
    Thank you for your help.
