MadMapper 5.5 BETA 3: AutoSave, 3D particles generator, 2 new modules and more
    by MADben » Fri Nov 17, 2023 3:38 pm
    Dear Mappers,
    Thank you all for testing MadMapper 5.5 BETA, we're glad to read that many of you loved the Laser Scanner.
    With the BETA 3 you can also test the new AutoSave feature, a fresh new 3D particles generator, as well as the Idle Cue and Device Activity modules!
    Download the BETA directly from your user account on the MadMapper website, don't forget to hit that big red button in the app to send us your feedback !
    We hope you'll enjoy this release !
    The MAD Team.
    MM 5.5.0 BETA 3 Release Notes
    ADDITIONS
    + Added AutoSave project (to be disabled before performance / permanent install)
    + Added 3D Particles generator
    + MadLaser: huge improvement in dispatching when using vectorized content (follow shapes from frame to frame to maintain them on same laser output)
    + Idle Cue module (after some inactivity in cue bank, start a specified cue)
    + Device Activity module (after some inactivity on a MIDI / OSC / Keyboard or Firmata device, change a channel value to be used in Controls - ie to start a Cue)
    IMPROVEMENTS
    * Space Scanner (video): image cleanup, huge improvement
    * MadLaser: Laser Render settings to define how to handle beams (single point), Auto or Fixed point count
    FIXES
    - Fixed a crash in Laser Output introduced in Beta 1 (big thanks to all of those who sent crash reports!)
    - Fixed reloading “Enable MSAA” on video outputs
    - BlackMagic runtime device check could lead in hickups in the output with some black magic devices connected
Users browsing this forum: No registered users and 59 guests
