layering content
  • NiceTrip
    layering content
    by NiceTrip » Fri Dec 01, 2023 7:23 am
    Hello, I'm just learning Madmapper, but I'm quite familiar with Resolume. Is there a way to create compositions by layering videos, shaders, materials, etc., with different opacity settings and/or blend modes for different layers? For example have a video with lots of black in it, and alpha channel, and would like to play a material or shader "behind it", on the same surface. Possible?
  • NiceTrip
    Re: layering content
    by NiceTrip » Sun Dec 03, 2023 1:08 am
    To answer my own question, hopefully to help out other MM newbies -- yes, it is possible. It is done in the stack of surfaces (top-left). Apply a video to a quad. Add another quad and apply another video to it. Change the Blend mode on the top quad to adjust how it interacts with quads below. You can copy and paste the masks from the first quad to the second one, to match the exact shape in the output. It is sort-of demonstrated in this video: https://www.youtube.com/watch?v=Trd93uPxvyw.
  • Dvadibra
    by Dvadibra » Wed Apr 24, 2024 9:44 am
    What file format and what codec would you advise for video with Alpha? I'm running windows 11 and davinci resolve.
    So far I've tried;
    - H.265 with alpha (the video work when reimported into resolve but doesn't have a working Alpha in Mad mapper)
    - HAP (this was converted from the H.265 to HAP Alpha, but again does not play with Alpha, unable to test if alpha is good as Davinci resolve does not import HAP)
    - DXV 444 High Quality With Alpha (this was rendered out from Davinci resolve and again ALpha tested by reimporting which worked fine but when played in Mad Mapper no alpha seemed present)
    I have tried all blend modes (though mainly I'm interested in Over (and over premultiply *though i will admit to not fully understanding the difference between the 2)
    basically HELP currently alpha seems broken / non existent to me
    thank you in advance regards David
    by franz » Thu Apr 25, 2024 5:42 pm
    HAP_ALPHA just works.
Users browsing this forum: No registered users and 74 guests
