Video flickers after 2h
  • jaybsound
    by jaybsound » Sat Dec 23, 2023 1:32 pm
    Hey guys, I was asked to VJ a club for New Years Eve. I was setting everything up with the clubs computer and projectors… But after around 1.5-2h the video starts flickering / changing brightness very slowly… it seems like an effect, but nobody touched the gear for over an hour. Restarting madmapper fixes the issue, but it cames back after 1.5-2h.
    The software Version was 5.0.7 and there no wifi / cellular connection in the club to update.
    Do you have any idea why this happens?!
    I can’t attach the video here, please watch it on reddit: https://www.reddit.com/r/madmapper/s/P85gu8FbO7
    Re: Video flickers after 2h
    by mad-matt » Thu Jan 04, 2024 12:46 pm
    Why not using latest version ?
    You can try to de-authorize and re-authorize MadMapper.
    Kind Regards
  • jaybsound
    by jaybsound » Thu Jan 04, 2024 8:57 pm
    Not that easy, as I said there no internet connection in the club and the computer is screwed down to avoid theft. Is that flicker a know issue that a new version fixes? Taking the computer home and updating it is a big hussle and I want to be sure that an update fixes it before a start that endeavour.
    by mad-matt » Fri Jan 05, 2024 1:35 am
    Please send a log file & the serial number activated on this computer to support@madmapper.com
    On recent MadMapper versions log files can be access from menu Tools / Show Log Files...
    On older version, you have to get files manually:
    Log files on windows are located in:
      "C:\Users\your_login\AppData\Roaming\Garagecube\MadMapper\Logs\"
    You can type this in file explorer address bar:
       %AppData%\Roaming\Garagecube\MadMapper\Logs\
    Log files on macOS are located in:
    /Users/YOUR_LOGIN/Library/Logs/GarageCube/MadMapper/
    To access this hidden folder easiely you can: open Finder, choose menu Go / Go to Folder… and paste
    ~/Library/Logs/GarageCube/MadMapper/
Users browsing this forum: Baidu [Spider] and 25 guests
