minimad with 2 artnet nodes
    DBR
    by DBR » Fri Jan 05, 2024 12:42 am
    for an autonomous installation, there are 2 artnet nodes (8 univers each) connected to a RJ45 hub.
    The ip address for the first node is : 2.13.2.252, the second is : 2.13.2.253.
    How should I configure the minmad network configuration please ?
    thanks in advance :)
    DBR
    Re: minimad with 2 artnet nodes
    by DBR » Thu Jan 18, 2024 10:29 pm
    ok after some few tests, it isn't difficulte at all. From Madmapper, juste built your led sequences and upload it to the sd card, the ip adress must be set to the first artnet node
    Et voilà :mrgreen:
    you can see our led installation running under 1 minimad and 2 nodes in the Geneva Lux Festival 2024 (under the Kiosk - Jardin Anglais)
