MiniMad outputs broadcast ArtNet although unicast is selected
  • PK_LW24
    by PK_LW24 » Thu Feb 01, 2024 5:39 pm
    hopefully someone here can help me with the issue that my MiniMad 5 outputs broadcast Art-Net instead of Unicast messages that is selected at Export to MiniMad.
    The MadMapper Output is set to unicast and the target devices are set correctly.
    Even the artnetunicast.csv that is in the mapping folder on the SD-Card of the MiniMad is correct:
    Code: Select all
    IP,Short Name,Universe,Active (0 or 1),Long Name,Remapped (0 or 1),Remapped Universe,Was Autodetected (via polling - 0 or 1) 192.168.42.22,DMX,1,1,DMX (Relays),1,0,0 192.168.42.21,PIX CTRL,0,1,PIX CTRL 1x36,0,0,0
    But when I sniff the network I can still see the broadcast packages (and not only the Art-Sync that has to be a broadcast for sure) :?
    Any help is appreciated.
    Re: MiniMad outputs broadcast ArtNet although unicast is selected
    by Pierre Guilluy » Thu Jun 13, 2024 6:29 pm
    What version of MadMapper are you using?
